Linky na zajimavé vědecké članky
Zlé vzpomínky lze přepsat, ale musí se to umět
http://www.osel.cz/index.php?clanek=4766
(nic extra novyho ale aspon to už maj trohu vědecky podloženy )
Re: Linky na zajimavé vědecké članky
Proč migréna zahání své oběti do tmy
http://www.osel.cz/index.php?clanek=4829
Par poznamek z orig člaku :
-chemicals that are thought to be released in a migraine attack - serotonin, prostaglandins and histamine.
-hypersensitive that they were stimulated by signals 100-times smaller than what’s required to induce any kind of activity in this nerve under normal conditions.
-One of the interesting things that we heard once we start talking to patients is during migraine attacks they become aware of the space between their brain and the skull. Nobody under normal condition can say that.
-But the nerves in the spinal cord which process the incoming information before the messages are sent to the brain. They become activated and hyper responsive too.
Professor Burstein Now here is the biggest surprise so far. Because the nerves in the spinal cord receive sensory signals from two sources, not only from inside the head but also from outside the head like from the skin area around the eyes the per-orbital area, the skin around the temples and the skin area around the eyes. Now what the animal studies showed us is that if we touch with the mildest forces the skin around the eyes, the nerves in the spinal cord fire or respond at the same intensity that they respond if we stimulate it with the most noxious stimulus. Now normal signals will transmit the wrong signal. They are translated from non-noxious signals into noxious ones. So, from non-painful into painful signals.
-They found that when people have a migraine headache, nearly 80% of them have hypersensitive skin over the area where they feel the pain - round the eye or to the side of the head.
-skin to like, you know, skin temperature is 32 degrees centigrade, it’s enough to warm it to 36 and it would be painful during migraine. While in the absence of migraine you need to warm it to 45, 46, 47 before they feel pain and they want to stop it.
-Like they can’t wash their hair, they can’t wear earrings, they can’t wear glasses because it hurts them on the contact side, they can’t breathe through their nose because the temperature of the air is colder when they breathe through their nose and it hurts them inside their nose, like they can’t take a shower in the morning because during migraine the water feels like needles when it touches their head. Like women can’t use hairpins to keep their hair together, it’s too painful. They had to cut their hair shorter because during migraine long hair, the weight of the hair was enough to induce pain in the scalp.
Tenhle članek poskytl docela dost zajimavejch souvislosti a par napadu ale neurochemie je dodt složita bude potraba to prozkoumat vic do hloubky
*pri bolesti hlavy by mělo pomoct blokovat modry světlo (viz clanek o serotoninu) melo by snižit produkci serotoninu a spustit jeho preměnu na melatonin tim snižit senzitivitu a bolest
*dalši z latek co tam podporuje tu hypersenzitivitu je hystamin takže by mhly pomct antihystaminika- prašky proti alergiji
*pak už je spiš vic otazek než odpovedi ty samotny 2 latky na to stačit nebudou bežne serotonin docela podoruje dobry pocity ,pohodu ,bdělost hystamin -bdelost..
neco jinyho se musi rozhodit bude potreba zjistit co určite co bude mit i neco společnyho z stresovejma hormanama ,negativni energiji,filtraci informaci v thalamu ,prefronatlnim kortexem ten jen zjistit co .
*samotna hypersenzitivita je pomerne zajima umožnila by vnimat mnohem vic než normalně jen ji to chce nejk držet pod kontrolou , už driv sem zjistil že pri negtivni nergiji je citit jkde je telo oslabeny tohle by častečne vysvetlilo proč telo se najdnou stane mnohem cilivejši na tyto problemy a ukaže se kde sou jeste to chce najit ten vypinač
http://scienceworld.cz/aktuality/pocita ... ivity-5486
chtelo by to original članku nejpiš stejne dost přehanej
z současnou technologiji se myšlenky zatim čist nedaj teda z tou oficialni technologiji
v jednom članku sem našel zminky o algoritmu pomoci ketryho se prevadej informace z kratkodobe do dlouhodobe pameti byl to sice jen navrch mechanizmu ale zajimavy
by byla stranda previst informace do formy ketrym mozek rozumi apak je tam nahrat bohužel zustava problem jak je tam dostat v članku bylo posnay jen kodovani na urovni jednotlivejch neuronu ketry asi bophužel nepujdou zamrit pokudteda nemaj nejakej specifickej signal . Ale povedlo se mi najit informace o signalu keterej zesiluje uladani dat do dlouhodobe paměti
zajimvy že je i jeho protiklad take by se dalo z mozku i neco vymazat
signal pak hodlam testnouz CES nebo magetickou stuulaci
Moc vedeckej clanek to neni
ale myslim ze by to tu mohlo byt
kdyz by ste na to nekdo narazil jinde,"vedecky", rozhodne to sem soupnete
osobne si myslim ze to jen potvrzuje to co uz dele vime
http://www.novinky.cz/koktejl/196073-sv ... -ocim.html
Nový pohled na zážitky blízké smrti, může prý za ně přemíra oxidu uhličitého
http://digiweb.ihned.cz/c1-42338350-nov ... uhliciteho
Promluvili materialistiNový pohled na zážitky blízké smrti, může prý za ně přemíra oxidu uhličitého
co se tyče NDE tak oxid uhličitej bude jen jednou časi skladačky zajimavy že se traba uvidi i v souvislosti z holotropnim dychnim ale tam ma byt jeho obsah v krvy naopak hodne nizkej
tak jako tak obe veci mužou spusobye chemiskou nerovnovahu a ta muže spustit celou radu dalšich věci
Nejdelší geomagnetická bouře od roku 2005 vědce překvapila, její příčiny nejsou jasné
http://gnosis9.net/view.php?cisloclanku=2010040006
-moc tam nepišou ale treba se s toho vyklube časem neco zajimavyho geomagnetocky pole muže souset ze spoustou veci treba i četnosti AC
nebo žeby nejakj naznak konce svta pretočenim polu (to už je hodne prehnany ale neni naskodu sledovat co se deje)
a čo vy na to:
Jak mozek mění naše sebe-vědomí?
http://www.osel.cz/index.php?clanek=4880Re: Linky na zajimavé vědecké članky
V članku nic novyho o tech častech mozku se vy už docela dlouho ...
Pokud umiš anglicky
http://forum.astralni-cestovani.org/vie ... f=30&t=676
http://forum.astralni-cestovani.org/vie ... f=30&t=680
Pokud umiš anglicky
DNA si vyměňujeme i bez sexu, pošťákem je bodavý hmyz
Dlouho panující představa, že získáváme genetický materiál jen od tatínka a maminky již neplatí. Vědci z Arlingtonu na Universitě státu Texas ukončili spory o to, zda bodavý hmyz, tím jak nám saje krev, může přenést do našeho těla DNA cizího člověka a zda se nám do genomu cizorodá DNA může zabudovat. Kromě vertikálního přenosu – tedy z rodičů na potomstvo, existuje také horizontální přenos genetického materiálu - mezi jedinci zcela nepříbuznými. Prozradily to na nás transpozony.
http://www.osel.cz/index.php?clanek=5024
zajímalo by mě, co je na tom pravdy. Jestli je to fakt.....tak klobouk dolu k takové proměně
http://www.velkaepocha.sk/2010052013322 ... ledky.html
Trochu sme to uz resili v tematu "astralni cestovani a pust"
jinak osobne bych rekl ze je to mozne!
Uz delsi dobu premyslim nad jednou veci: Vim ze vse co se deje, ma nejakou logiku a smysl. Konkretne ted mam na mysli nemoci, urazy a podobne. Nebyl jsem ale zatim schopen prijit na to, jaka "logika" se skryva za "kazenim zubu" a jejich bolesti...
Ted uz je mi to take jasne
a verim ze uz i vam - jidlo je "nepotrebne"! Je to jen vytvorena "zavyslost" aby nas mohli lepe drzet na nizkych hladinach vibraci. Bohuzel i kdyz to vim, tezko se mi s tim vyrovnava
ale postupne zacinam pustovat a uvidime jake vysledky to prinese...
Kazdopadne po trech dnech pustu sem nemel potrebu cistit si zuby
jelikoz byly hladky(bez plaku) a usta bez zapachu...
Mejte se krasne!!!
Mejte se krasne!!!
njn...neni nad pěkně vosmažený topinky s pořádnou vrstvou česneku (neboli dech zabiják)
Dám to sem, bo nevim kam jinam by se to hodilo.
Sice to nemá s timdle fórkem moc společnýho, ale myslim že si každej rád přečte
http://xman.idnes.cz/osm-signalu-ze-jst ... n-styl_fro
........a dole sou další zajímavý vodkazy
