https://www.researchgate.net/publicatio ... citability
5Khz 20uA/cm2 6*8cm 10min +80%MEP 60-90min after effect
http://www.researchgate.net/publication ... al_studies
*Low-frequency AC stimulation (2–7Hz) strongly modulated the gamma power at the stimulation frequency
*at endogenous f increase of power at sub-harmonic
*low stim at endogenous by resonance *inhibitory neurones are less sensitive to stimulation
*theta gamma coupling
http://www.researchgate.net/publication ... pple_range
140hz tACS +40%MEP
LD by tACS
Re: LD by tACS
Re: LD by tACS
Lets start form beginning:
First we want to know difference between dream and LD
Neural Correlates of Lucidity
Neural Correlates of Dream Lucidity Obtained from Contrasting Lucid versus Non-Lucid REM Sleep: A Combined EEG/fMRI Case Study
Notes:
Activity related to lucid dreaming. Color coded clusters represent areas significantly activated during lucid epochs in REM sleep (pFDR < 0.005): left hemisphere (A), right hemisphere (B), midline view (C). Predicted (green) and fitted (black) fMRI data of the peak activation in the right precuneus, showing combined analysis of two independent lucid epochs in a single subject (boxed) (D).
DISCUSSION
Neuroimaging studies have shown that human REM sleep is related to characteristic patterns of regional brain activity: During REM sleep, neural activity in the brain stem, thalamus, amygdala, and extrastriate temporo-occipital cortices increases, while, e.g., the dorsolateral prefrontal cortex and the precuneus show deactivation.1 This specific pattern of neural activity has been proposed to reflect the visual hallucinations, emotional intensifications, and cognitive abnormalities typically experienced in dreams.2 In contrast, lucid dreaming is characterized by a regaining of higher cognitive capabilities, eventually leading to the awareness of the dreaming state. Recent quantitative EEG data have shown that this wake-like intellectual clarity is paralleled by neural activations in frontal and frontolateral regions.3 Likewise, PET data show cognitive control in dreams to be associated with activation of frontal cortex components.8
Here we present neuroimaging data showing lucid dreaming to be associated with neural activations in a specific network of cortical regions. In line with the study of Voss et al.,3 during lucid dreaming we observed increased activity in the right dorsolateral prefrontal cortex. The dorsolateral prefrontal cortex is thought to underlie a wide range of higher cognitive capacities, as evidenced also by the dysexecutive syndrome seen in patients with lesions in this region.9 In particular, the right dorsolateral prefrontal cortex was associated with self-focused metacognitive evaluation.10 While in normal dreams, working memory is strongly impaired,2 activation in the dorsolateral prefrontal cortex in combination with parietal lobules, which we also found to be activated during lucid dreaming, may reflect working memory demands related to task performance in our study.11 We further observed increased activation in bilateral frontopolar areas, which have been related to the processing of internal states, e.g., the evaluation of one's own thoughts and feelings.12
The strongest increase in activation during lucid compared to non-lucid REM sleep was observed in the precuneus, a brain region that has been implicated in self-referential processing, such as first-person perspective and experience of agency.13 While in normal dreams, attention is often hyper-associatively driven by the (pseudo-)external dream scenery, lucid dreaming is—by definition—characterized by a reflection on one's own state of mind.
*precuneus
Lucid dreaming and ventromedial versus dorsolateral prefrontal task performance
http://www.sciencedirect.com/science/ar ... 0010001492
Notes:Participants who exhibited a greater degree of lucidity performed significantly better on the task that engages the ventromedial prefrontal cortex
Notes:
DISCUSSION
*precuneus
Re: LD by tACS
Testing the involvement of the prefrontal cortex in lucid dreaming: A tDCS study
http://dnl88.files.wordpress.com/2013/0 ... cs-pfc.pdf
Notes: only work for experinced LD dreamers
Re: LD by tACS
Lucid Dreaming: A State of Consciousness with Features of Both Waking and Non-Lucid Dreaming
http://www.ncbi.nlm.nih.gov/pmc/articles/PMC2737577/
Re: LD by tACS
Psychophysiological correlates of lucid dreaming.
Holzinger, Brigitte; LaBerge, Stephen; Levitan, Lynne
Dreaming, Vol 16(2), Jun 2006, 88-95. http://dx.doi.org/10.1037/1053-0797.16.2.88
Abstract
The main goal of the present study was to explore electrophysiological differences between lucid and nonlucid dreams in REM sleep. Seven men and four women experienced in lucid dreaming underwent polysomnographic recordings in the sleep laboratory on two consecutive nights. EEG signals were subjected to spectral analysis to obtain five different frequency bands between 1 and 20 Hz. Lucidity was determined by both subjective dream reports and eye-movement signals made by the subjects in response to light stimuli indicating a REM period. The main discrimination factor between lucid and nonlucid dreaming was found in the beta-1 frequency band (13-19 Hz), which in lucid dreaming was increased in both parietal regions. The ratio of frontal to parietal beta-1 activity was 1 to 1.16 in nonlucid and 1 to 1.77 in lucid dreaming. A tendency towards the greatest increase was observed in the left parietal lobe (P3), an area of the brain considered to be related to semantic understanding and self-awareness. (PsycINFO Database Record (c) 2012 APA, all rights reserved)
Abstract
