Stránka 3 z 3
TEST: Eye catalepsy
Napsal: úte, 28. kvě 2013, 12:25
TEST: Eye catalepsy
Close your eyes
take a deep long breath in
and out
As you breath out your eyes become more and more relaxed
in and out
Let all tension in your eyes mett away
in and out
More and more with every breath
and when you know you have relaxed those eyes and you know they will not move you can try to meve them
... and you will find that they just won't work....
That's right... you can try but they just don't work..
.. so you can stop testing now...
and just enjoy that feeling of relaxation getting deeper and deeper....
Re: Mind programing
Napsal: úte, 16. črc 2013, 00:44
Re: Mind programing
Napsal: sob, 19. říj 2013, 22:38
Re: Mind programing
Napsal: pát, 01. lis 2013, 14:21
Back passive
Back passive after oči
Back passive after tělo
Re: Mind programing
Napsal: pon, 18. lis 2013, 16:15
fronto-parietal areas (particularly the precuneus) also suggest their critical role in sustaining the level of consciousness
During lucid dreaming the bilateral precuneus, cuneus, parietal lobules, and prefrontal and occipito-temporal cortices activated strongly as compared with non-lucid REM sleep.
Re: Mind programing
Napsal: pon, 18. lis 2013, 19:57
od Elen
Promin, že sem píšu, ale ten obrázek, jak ta dívka leží v té vodě, to je u mě docela častý vjem:-) Obvykle ale mam i místo chodidel ploutev, kterou se vlnim vodou:-)
Re: Mind programing
Napsal: úte, 19. lis 2013, 19:44
Obrazky sjou planovany jakou součast rizene vizualize prave dotek z vodoua jeji teplota mohou sen stabilizovat a zaroven je tam minimalni rozpor z polohou těla dotekem z posteli.
Re: Mind programing
Napsal: ned, 22. pro 2013, 20:28
MyOS
2 programy nemuzou mit stejnou prioritu , hlavne pokud vzuzivaji stejne zdroje
sekne se to na tom ze nemuze zvolit.
Pri tvorbe programu v Myos ma vše velkou prioritu ale problem že stejne velkou.
EMOCE
EMO*ACT*PFC*ATT*AMP
Sugesce funguje vždy pokud :
je dobře definovany co ma dělat
je to možny
neni v rozporu z jinym programem (vírou,sugescí) , připadne ma vetší prioritu
ospovída situace kdy ma být aktivovaná
Sken negativnich emoci
Sken pozitvnich emoci
Sken metod na čisteni
Re: Mind programing
Napsal: pon, 10. úno 2014, 17:14
Celk N produkce 37 N/min
ATT 1,6 N/min
Rc 22 R
ATT EMO N 0,6N/min
ALARM 7 N/min
ALARM-H 29N/min
ALARM-H
count :7
svaly -krk
svaly-oči
zuby
ALARM-H AMP 2650% OPT
Myos: ALAMRM-H AMP SET to 100% OPT
Error: 37 collisions
Myos: collisions find base data and update
Update in progress 7 errors left
Update in progress 4 errors left
Update in progress 2 errors left (22:01)
Re: Mind programing
Napsal: úte, 11. úno 2014, 01:03
Celk N produkce 17N/min
ATT 7,2
Rc 76 R
ATT EMO N 1,5N/min
ALARM 0,02 N/min
ALARM-H 1,3N/min
14 N/min ?
Bolest 14 N/min
Bolest AMP 75% OPT
Bolest ALARM 1N/min
Bolest ALARM AMP 3260 % OPT
Myos: set ALARM-BOLEST AMP to 100% OPT
